Rough layout design, input please.
JackW
Member Posts: 236
Ok, this is a rough draft following a design I have posted a couple of times asking for input. Ratio suggested I draw up a preliminary design for you guys to take a look at, so here it is. As you can I can't draw worth a darn, hope you can make sense of it. Any and all input will be greatly appreciated. The layout I am using as a template is below it.
Thanks,
Jack
Thanks,
Jack
Thanks DZoro. Wont I have to pipe the pumps horizontal instead of vertical so I don't have to come up from the bottom? I'm going to change the output and input manifolds around so I don't have to cross over the return line. I do plan on putting gauges and a strainer in I just forgot to put it in the drawing. I'm going to start piping it up so I will post a pictures as I go. Thanks again.0
Ok. When I get it piped I'll post a picture. Thanks again for all your help.0
