Question for Taco guys
Solid_Fuel_Man
Solid_Fuel_Man Member Posts: 2,644
Will the 00e series of ECM circs bolt into the PSC volutes? I should just buy one and see, but asking first is easier!
Sometimes it's just less hassle to not mess with the flange gaskets or an inverted flange pump, and the universal flange looks goofy!
DZoro
  • SteveSan
    SteveSan Member Posts: 287
    I just spoke with the Product Manager here at Taco and he confirmed that you would need to change out the pumps. The motor and impeller are geometrically different from the 007-F5 to a 007e pump and so on. Please let me know if you have other questions. Taco tech Support is available Mon-Fri 8am-5pm EST @ 401-942-8000.
    Solid_Fuel_ManZman
  • Solid_Fuel_Man
    Thank you! That's service.
  • SteveSan
    You're welcome, have a great day!
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,360
    Thanks, @SteveSan!
    President
    HeatingHelp.com
    Timco
  • SteveSan
    You're welcome Erin.
