Taco ZVC406-EXP & Smart Thermostats
john p_2
Member Posts: 367
Looking to install wifi thermostats on my older Taco zone control panel and need to know where to locate my Common wires. I attached a pic showing where I believe they should go...
Yes you can get your Common at that C terminal.0
The R & C should be on the same transformer. Maybe this diagram will help you. It came to me from the engineers at Nest.
No I'm more confused...I thought common wire was the negative lead....do I need to jump the R & C wires in the thermostat?0
You will fry your transformer if you add that jumper.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Allan , thanks was pretty sure of that.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
