Taco ZVC406-EXP & Smart Thermostats
john p_2
john p_2 Member Posts: 367
edited October 2019 in Gas Heating
Looking to install wifi thermostats on my older Taco zone control panel and need to know where to locate my Common wires. I attached a pic showing where I believe they should go...
    HVACNUT Member Posts: 7,436
    Yes you can get your Common at that C terminal.
  • HomerJSmith
    HomerJSmith Member Posts: 2,775
    The R & C should be on the same transformer. Maybe this diagram will help you. It came to me from the engineers at Nest.
  • john p_2
    No I'm more confused...I thought common wire was the negative lead....do I need to jump the R & C wires in the thermostat?
  • You will fry your transformer if you add that jumper.
  • john p_2
    Allan , thanks was pretty sure of that.
