Steam Radiator Valve repacking ?
ericsch
Member Posts: 8
Hello , I have some steam radiators that leak from the valve stems . They need repacking but Im told not to use teflon packing or graphite packing . So what do I use? These are just your ordinary steam radiator valves you see in most homes . They have the black plastic circular handle to open and close them. So what do I use ? How many inches of whatever do I use ? and do I wrap it around the stem counter clockwise or clockwise? Thank You .
I'm a little confused by the question, Teflon or Graphite packing are the only options I've used on the bonnet nuts on my 9 rad valves, and more recently tried Palmetto packings 1382 1/8" which seems to be excellent - combination PTFE and Grahite. Three or four wraps, clockwise, then snug down and work it in a bit. I may repack all of them with this stuff - the white teflon cord I used before on the majority of these valves seems to be inferior.
https://palmettopackings.com/packing-products/general-service-packings/style-1382/0 -
Some rad valves are "packless", if so not able to fix with standard packing. Someone may have known this and this is where the advice came from.
Pictures would tell us something about the valves.0 -
Agreed, pictures = good0
By whom? People love to comment on things...ericsch said:Im told not to use teflon packing or graphite packing
Use Teflon, or graphite, or wick. Don't over think it.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
Danco and Grainger both said teflon will melt and graphite isnt appropriate ??0
I will check out the Palmetto packings stuff but it looks a little thick0
I wish someone would just make a thick silicone washer with a tapered top that would stop any leak by compression
I will try the danco graphite stuff from home depot . 4 turns around the stems clockwise . Ive tried teflon and graphite string both didnt stop the leaks much0
Thanks to all the replies , I was expecting emails about having messages . Thats why the late reply .0
the home depot graphite looks more substantial that the graphite string i tried . When using the teflon what do you think works better , the thin rope or the thicker rope?
will meltericsch said:Danco and Grainger both said teflon will melt and graphite isnt appropriate ??
And it's good to 550 degrees
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
