Some days, I am just in awe....
delta T
Member Posts: 884
at the lengths some people will go to to "save money on heating".
Went to do a tune up for a new customer today......found this. 3" water heater flue runs downhill for about 10' to the connection you see.
Will be replacing the water heater with a side arm, fixing the flue and doing some minor repairs. The boiler itself seems to be in pretty good shape at least!
1
These people just bought the house, previous owner claimed that it heated the whole basement by itself! (That and the 60' of baseboard....)0
I've heard of Magic Heat units before but this is the first time I've seen one in the wild!
Must be magic to make the flue gases go down then back up like that lol0 -
Can't fix stupid..................All Steamed Up, Inc.
Consulting1 -
Oh I have a hard-headed cheap customer with one on an oil burner flue pipe.
“Heats the whole basement for 'free'”.
I posted the pic before...
I make him take it off and remove the wiring before annual pm.
This is a diy job. He solved the ghost flow issue by installing zone valves on each circulator zone.
Won’t pay to clean up any controls/wiring/piping.
2 -
Too cheap for a 15-second primary too.All Steamed Up, Inc.
Consulting0 -
Not to mention the scorched wood behind the manifold.0
Replacing the WH with a sidearm, somebody is going go be very disappointed with their 7 second showers before they run out of hot water0
@GroundUp I gotcha, yeah I meant an IDWH, in my neck of the woods, the two terms are interchangable. Are you talking about an everhot or similar heat exchanger?
Funny how we all have slightly different terminology. I had a distributor get rather angry and upset with me when I tried to order a PRV (Which is what I call a Pressure Reducing Valve). He insisted that a PRV was and could only ever be a Pressure Relief Valve. He actually got so upset about it that he hung up on me
I thought I was being pretty nice about it....guess he was having a bad day Lol> 1 -
Hi @GroundUp , Watts, who invented the temperature and pressure relief valve calls it a T&P relief valve or T&P. Your distributor must have been having a bad day, cuz he had it wrong.
Now for pressure relief only, they call it "water pressure relief valve", "safety relief valve" and "boiler pressure relief valve". It could get confusing!
Yours, Larry0 -
That darn terminology! What I refer to as a sidearm, is literally a "side arm" HX on a tank style WH, basically a pair of tubes inside one another where boiler water runs between the inner and outer via a couple tees and domestic on the inner tube via reducers at the end. Most often used (here anyway) in outdoor boiler applications with constant circulation and create a thermosiphon to keep the tank hot with no additional circ. The output is very low however, so the picture I had in my head was just a 4ft long copper log hanging in place of a tank hoping for on-demand heating like a plate HX would provide.0
I find those stack robber's, tend to soot up modern Boilers. Too low a stack temp.STEVEusaPA said:Oh I have a hard-headed cheap customer with one on an oil burner flue pipe.
Won’t pay to clean up any controls/wiring/piping.0
