Galvanized pipe on wet return
Steve_210
Member Posts: 664
Changing a boiler today what are the consequences of galvanized pipe on wet return obviously it was something somebody had left over from a job
Galvanized pipe rusts. Remarkably rapidly. The possible consequences are slow returns from the rust clogging things up and, eventually leaks. If possible I'd replace it either with black iron or, since it's a wet return, copper.Br. Jamie, osb
Yes I know how to replace it with copper just didn’t know what the consequences were thanks0
Strange galvanizes is used outside because it doesn’t rust0
Worse, in some cases the galvanized flakes off. I believe hte low PH speeds up corrosion as mentioned. It has poor chemical resistance in general. That’s by it’s sort of OK for potable water, but not as good as plastic or copper.
Galvanized still rusts outdoors, only much, much slower than plain steel that rusts instantly the protective film of machining oil is gone.
Remember too that galvanized pipe is usually steel, not iron. Steel rusts like mad once the galvanic coating is breached. Black iron rusts very slowly.Br. Jamie, osb
Correction yes galvanized will rust but much slower a lot of codes required galvanized for outdoor gas pipework
- 120 Geothermal
