Panasonic bath fans
ChrisJ
Member Posts: 17,070
Hi all,
Does anyone know what the differences are between the Panasonic bathroom fans? For example, Whisper Green, Ceiling , Whisper Value?
I looked as close as I could and came up empty.
For example the Whisper Ceiling vs Whisper Value specification wise seem virtually identical but there's a $100 difference.
What gives?
What gives?
> @STEVEusaPA said:
> The night lite?
I think they both have that too.
The night light, one of the best things I ever put in the bathroomSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The best I can tell, the more expensive one is more aimed at energy efficiency between tightening the envelope and using less power. It also makes very slightly less noise. Also the Value series is more of a pre-set speed and you get what you get for each setting where the better ones apparently regulate them selves to achieve the actual requested flow.
The overall real world performance differences aren't much though from what I can tell.
The Whisper Green appears to have options for constant circulation and then has a second high speed for when you go in and destroy the bathroom. Both can be set to whatever flow you want.
Out of the 3 I looked at, no, nothing that fancy.JUGHNE said:Do either have humidity sensors?
Has anyone developed a nasty smell indicator with auto on?
Nasty smell auto on would be a nice feature, but no I don't think so.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Free one with every marriage...JUGHNE said:...Has anyone developed a nasty smell indicator with auto on?
2 -
I actually use an aquastat on the hot water pipe to the shower to automatically run yhe fan. You can regulate how long after the shower it stays on with how much insulation you put on yhe pipe.
I also have a mechanical clock spring timer right beside the toilet for nasty smell removal.
This way the bathroom fan never gets left on, and cannot be forgotten to be turned on. My wife just puts up with my obsessions.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
The “green” ones have a high efficiency ECM motor. One of them may offer a low constant speed to meet min. Ventilation requirement. Options include a motion sensor and humidity sensor.
The ECM is constant torque and compensates somewhat for ductwork resistance to achieve nominal CFM. A normal cheap fan uses a relatively inefficient shaded pole AC motor that’s constant RPM.0
