Steam boiler
Snowmelt
Member Posts: 1,428
I took one apart Friday, waiting for customer to have money for new boiler. My supply house boiler guy took a section , dropped it on the ground and it broke in two, he thinks it was dried firered.
Looks like good ole..rotted out. Can't seem to click on the pic to zoom in.
Could be just rotted. Could also be... brittle failure. Keep in mind that cast iron is brittle, not ductile (why bashing a cast elbow can break it off so you can replace it!) and perhaps your supply house guy dropped it far enough for the shock to break it. Impossible to be sure unless you can study the fracture surface closely.Br. Jamie, osb
He dropped a few sections and didn’t break, he dropped the 4th section at same height and it broke, then you can see the fresh metal vs the metal that was all rusted. If that makes any sense?0
Just depends on exactly how it hit. Possibly with latent flaws in the casting. Plink!Br. Jamie, osb
Just for clarity...what's the question?
Question is, where the hell all that soot come from, and if I never saw water on the ground that doesn’t mean it didn’t have a leak0
I can't tell from the photo, but how much of that pile is soot vs rust I wonder?
Why would dry firing it make it brittle?
I would expect the typical conditions to anneal cast iron if anything. I don't think it was dry fired based on the evidence provided.
Cast iron is brittle by nature.
Quite correct on all counts, @ChrisJ !ChrisJ said:Why would dry firing it make it brittle?
Cast iron is brittle by nature.Br. Jamie, osb
From the field. https://share.icloud.com/photos/0eG1UKU14RC0rif7lE5WpkQiQ
It cracksGennady Tsakh
Absolute Mechanical Co. Inc.0 -
Dry fire a cast iron boiler long enough and the sections will melt. Actually, firing any boiler, steel or cast iron and they will melt. I have seen it happen many times.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 993 Plumbing
- 389 Solar
