repair air valve threads on radiator
lakefruit
Member Posts: 18
Hi Guys. One of my radiator has bad thread. It is so bad that regular 1/8'' tap doesn't work anymore. I looked at internet and found this video that showed to drill a bigger 1/4'' hole and use an ⅛-inch to ¼-inch bushing.
https://www.thisoldhouse.com/how-to/how-to-repair-radiator-air-vent-threads
Has anyone done this before, is it relatively easy for an average ppl? I am kind of afraid that I might damage the radiator.
Thanks
Thanks
I'm a bit above average
and I wouldn't hesitate to try it. The biggest thing is getting the npt tap. And don't drill a 1/4" hole, drill the size the tap asks for.
Also regarding your concern about damaging the radiator, sounds like it's already damaged!NJ Steam Homeowner.
That's when you can afford to be bold! You got thislakefruit said:@ethicalpaul true. It is already damaged.
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
