repair air valve threads on radiator
lakefruit
Member Posts: 18
Hi Guys. One of my radiator has bad thread. It is so bad that regular 1/8'' tap doesn't work anymore. I looked at internet and found this video that showed to drill a bigger 1/4'' hole and use an ⅛-inch to ¼-inch bushing.
https://www.thisoldhouse.com/how-to/how-to-repair-radiator-air-vent-threads
Has anyone done this before, is it relatively easy for an average ppl? I am kind of afraid that I might damage the radiator.
I'm a bit above average
and I wouldn't hesitate to try it. The biggest thing is getting the npt tap. And don't drill a 1/4" hole, drill the size the tap asks for.
Also regarding your concern about damaging the radiator, sounds like it's already damaged!NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
That's when you can afford to be bold! You got thislakefruit said:@ethicalpaul true. It is already damaged.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 393 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 46 Industry Classes
- 49 Job Opportunities
