super tech
GW
Member Posts: 4,693
Hmmmm, yes, voltage is 0. This must be why its not working......0
I can't believe they posted this pic. It shows the location of the super secret factory test ports! All you have to do is hold your meter leads over the right spot (it's different for each mfgr, thank goodness!) & the computer inside will electrostatically couple to your meter & use the voltage display to show the fault codes for every single thing that can go wrong. It cuts my on-site time so much that I generally have to spend a half-hour in my truck 'filling out paperwork' after each job.3
If you zoom in you'll see the meter is made by Fisher Price. The cow says...0
As long as the homeowner is happy I guess it’s all good0
it looks like the coveralls that tradespeople in Europe wearBob "hot rod" Rohr
Poor guy. At least he's using both leads.0
Looks like he's just checking continuity through the plastic. Better safe than sorry.0
Pretty sure that's a DMM in the eyes of most people.nibs said:@HVACNUT
Well he does have a rather cute VOM.
When I hear VOM I think of the classic Simpson or Triplett analog meter.
Yes, the guy is measuring plastic and I'm going to argue abbreviations.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
> @nibs said:
> @ChrisJ
> The young lady wants to look at the pointer, not a bunch of numbers.
> Anyroad VOM.s are better at reading plastics, I was using them long before DMM's came into being
I use my Simpson 260 7P for certain things and I used to use a HP true RMS VTVM to test amplifier power and align tuners.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Maybe if he fixes the lack of continuity she will pour him a nice glass of that mushroom juice she has brewing0
I’m not a soldering iron person, yet I hear it’s just as simple as soldering tube. Doesn’t the young woman require solder in her opposite hand?0
@PRR
So I love how they are trying to project a message of safety. Look I got goggles on!!
Yet if somebody were to plug the tool in on her or if a homeowner look at the picture and try holding it that way themselves.
Typical ignorance. so ironic.I am the walking Deadman
Hydronics Designer
Hydronics is the most comfortable and energy efficient HVAC system.0 -
You can't fix stupid...................All Steamed Up, Inc.
Consulting0 -
Heating tools have handles so you don't hold the hot end. Her soldering iron, the black plastic with grey finger-grip is the handle. The shiny tube (scorched on the end) is the hot-part.
So, bad paste-up. Hold your plumbing torch by the burner with your finger in the fire. That's about what she is doing. (Slightly better because the iron temperature is about half as hot as a flame.)
As neilc says, every e-soldering tech has grabbed the wrong end, and cringes at this picture.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
