Residential Water Tube Boilers
Steve Minnich
Steve Minnich Member Posts: 2,868
I have absolutely nothing against these boilers. If you pipe them right and provide the necessary flow, they work great.
But I was wondering if anyone knew if any manufacturers considered going with a tube coil that’s larger?
I assume the downside to that would be less heat transfer? Larger boilers?
Steve Minnich
    hot_rod Member Posts: 25,517
    I know there are a handful of other water tube designs out there. here is a Viessmann and I think ECR style. Sermeta in the center.
    Steve Minnich
  • Henry
    Henry Member Posts: 998
    HTP is using a new version of the Gianoni HX with larger passages. 400K to 2 million BTU.
    Steve Minnich
