Residential Water Tube Boilers
Steve Minnich
Member Posts: 2,952
I have absolutely nothing against these boilers. If you pipe them right and provide the necessary flow, they work great.
But I was wondering if anyone knew if any manufacturers considered going with a tube coil that’s larger?
I assume the downside to that would be less heat transfer? Larger boilers?
Steve Minnich
I know there are a handful of other water tube designs out there. here is a Viessmann and I think ECR style. Sermeta in the center.Bob "hot rod" Rohr
Living the hydronic dream1 -
- 129 Chimneys & Flues
- 122 Geothermal
