Megapress fittings
SeanBeans
Member Posts: 525
So I have been tasked with running a new steam main and all of the corresponding run outs to the rads..
I haven’t been there yet but I’ve been told that the pipes coming down have all been sawzalled nearish the floor joists.
Do they make reducing megapress elbows? I doubt they make eccentric bushing..
My other option would be to really start from scratch and start from the rad and work my way down
Why would they have cut them off.....thinking of more head room?
Megapress is good for steam?
I think the dead men piped from the main up.....no unions.0 -
I’d start from scratch, BUT that’s me, no mega press for me.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Can’t you couple on, the floor above? If they chopped the pipe too tight it’s not your fault0
I've used a welder for that. I understand some contractors cut them off flush so the system can be salvaged easily so they can sell them a new systemTo learn more about this professional, click here to visit their ad in Find A Contractor.0
The company’s thought is to just use the mega press to get out of the joist and use black iron for the rest0
if they cut them flush you may have trouble getting the gun on straight without hitting the next floor joist. It's rated for lp steam. no reducing ells, no eccentrics ....couplings and elbows and not much more.
If there's union on the rads maybe you can break the unions and let them drop go downstairs and press a coupling on......if you have trouble getting the gun on that is0 -
When I learned about the job, the guy who told me about it said that he cut the pipes. And he assumed he would be the one going back.. so I think that he cut them with enough room to work on them.. we hope!
It got pushed back til around Labor Day0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
