Adapter for radiator valve when tail piece (stub) is too short
EdwinD
Member Posts: 159
Just an FYI,
I installed a new 3/4" radiator valve, but the tail piece is too short. The distance between the tail piece and radiator is an additional 1/4" longer than what appears in the picture. The reason being, a portion of the old stub is still in the radiator, which I had to cut, saw and chip out.
I found a solution using a 3/4" Female x 3/4" Male Nipple Bush Adapter . I tried joining a close nipple with 3/4" coupler -- yet it was too long.
Here's the final result.
Weil-McLain EG55 2 pipe Vapor System
OP Pressure .10 -.25 oz
8-Way Boiler Water Treatment
Barnes & Jones Big Mouth Vents
1
@JakeCK Correct - it says 304 stainless. Thanks - good pickup. Now that you mention it, I'm more concerned with the brass and stainless steel 304 interaction. I found a similar brass fitting to arrive tomorrow. Thanks.Weil-McLain EG55 2 pipe Vapor System
Barnes & Jones Big Mouth Vents0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
