Bypass between supply and return headers / manifolds?
I've got a 3/4" copper connection between my supply and return labeled "bypass". It includes a ball valve with the handle at 45 (versus the direction of flow). Hoping someone can explain its purpose. Thanks
    hot_rod Posts: 28,350
    got a pic? Some manifolds have pressure bypass valves added on or built in. Sounds like the valve you have is a way to isolate the branches.
  • woobagooba
    woobagooba Posts: 186
    Here is a pic of the return manifold (supply "manifold is tangle of CI and copper in the ceiling). The bypass valve in question is on the far left end of the return manifold.
  • STEVEusaPA
    STEVEusaPA Posts: 6,505
    It's the cheap and horrible way to do boiler protection.
  • woobagooba
    Please explain
    what type of boiler?
    Why a bucket under the BFD vent pipe?
  • woobagooba
    Its me again :)
    https://forum.heatinghelp.com/discussion/170834/buderus-gb142-multiple-corrosion-issues#latest
    Pay no attention to the bucket. That was wanna-be-HVAC-guy draining the failing ST120 to pull what I expect to see is a decimated anode.
  • Steve Minnich
    Steve Minnich Posts: 2,964
    Looks like a modcon? Nothing to protect.
    Steve Minnich
    HVACNUT Posts: 7,692
    edited August 2019
    It's a Buderus GB-142.
    If its piped directly back to the return without anything else inline, shut off the valve, remove the handle and zip tie it near the valve. A bypass is counter productive on a mod con.
    And whether it was supposed to be a boiler bypass or system bypass, its piped wrong either way.
    Noel
  • woobagooba
    @HVACNUT Roger that and thank you
