HTP install
lchmb
Member Posts: 2,997
Just curious: if all your zone require TMVs, why not let the boiler's ODR control the SWT? Assuming they're all within about 15* of each other.Bob Boan
I would have done that if I had a design temp on the zones. In this case the customer installed his own zones and is not sure what temp he's planning to run them at. I plan to set them all low and allow him to do what he wish's..0
Beautiful work.
Lochinvar Knight has 3 setpoints with reset curves:
http://www.lochinvar.com/_linefiles/KHN-02 B.pdf8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Looks great! If you have any questions or concerns, please feel free to reach out to me directly at tim.white@htproducts.com
TimJust a guy running some pipes.0 -
Thanks Alan, I'll keep that in mind but the company i work for sticks with a small number of units. The HTP has been a good system for us. And thank you Tim. I'll be starting the system tomorrow once the plumber get's the water on for me.
Nice work, and good to see I'm not the only one using the Watts RBFF to connect the expansion tank0
- 15.8K Strictly Steam
