How long for an iced coil to melt?
Chuck_17
Member Posts: 148
Ball park guess? - 1 day? 2 day?
Older residential outdoor packaged cooling only probably 1-1/2 or 2 tons.
It is off now. 72 out now. Probably down to 60 over night.
I don't know if there would be any air flow if it were not a block of ice.
If totally iced so the fan can't move air through the coil it could take a few hours.
Get a hot water hose on it to thaw it faster.
No ice picks0 -
Cooling only probably?
What's frozen? The evap or condenser?
And why did it freeze?0 -
Thanks for the replies.
There was no air flow. I don't know if it is because the evap coil was totally frozen (not letting air through) or that is the reason it is frozen (fan failed for some reason).
(I could only see the end of the coil though a service access panel. It was all ice.)
Hair dryer takes patience. Set up a big fan when it's warm outside and go have lunch.0
Sounds like you need a pro.0
If it's a big block of ice, I let it sit overnight. Sometimes a garden hose off is the drain of the water heater. It makes a mess though.0
Odds are the suction line is well frozen too. You can thaw the coil rather quickly with the blower on but if the suction line is frozen under the tubing insulation, that will throw off readings when the tech is trying to recharge it.0
warm water from a hose is the fastest if you can control the water0
