need 5 wire thermostat with heat anticipator
sjay
Member Posts: 15
Just bought condo and need to replace thermostat with one that has a 5 wire connection and heat anticipator to adjust for shorter more frequent cycles. The newer ones can handle 5 or more wires but no adjustable cycles, the older type have adjustable cycles but only have 4 wire connections, HELP
Make/model # of thermostat
Make/model # of equipment.
Or buy a different thermostat.There was an error rendering this rich post.
any make or model as long as it can have 5 wires connected to it and has adjustable length on off cycles.0
Rc, Rh, C, W ,Y, G.
Is that all you need?
Is it a heatpump? Is either terminal O or B being used?
Theres only about a bajillion thermostats that offer those terminals.
Look at the Honeywell T6 Pro. Nice but simple. You set the CPH as needed.0 -
Thanks HVACNUT,i'll look for T6 Pro,yesterday went to home dpot and checked all their models about 15 and older ones had adjustable cycle but only 4 wire connections, newer ones had spaces for 8 wire connections but none of those had adjustable cycle.0
What are the 5 wires used?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Your making this harder than it has to be. A common wire is not needed but optional with Honeywell T4. It uses batteries to operate.
Is this a conventional gas/electric setup or heat pump?Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
