need 5 wire thermostat with heat anticipator
Just bought condo and need to replace thermostat with one that has a 5 wire connection and heat anticipator to adjust for shorter more frequent cycles. The newer ones can handle 5 or more wires but no adjustable cycles, the older type have adjustable cycles but only have 4 wire connections, HELP
  • STEVEusaPA
    Make/model # of thermostat
    Make/model # of equipment.
    Or buy a different thermostat.
  • sjay
    sjay Member Posts: 15
    any make or model as long as it can have 5 wires connected to it and has adjustable length on off cycles.
    HVACNUT Member Posts: 7,526
    Rc, Rh, C, W ,Y, G.
    Is that all you need?
    Is it a heatpump? Is either terminal O or B being used?
    Theres only about a bajillion thermostats that offer those terminals.
    Look at the Honeywell T6 Pro. Nice but simple. You set the CPH as needed.
  • sjay
    Thanks HVACNUT,i'll look for T6 Pro,yesterday went to home dpot and checked all their models about 15 and older ones had adjustable cycle but only 4 wire connections, newer ones had spaces for 8 wire connections but none of those had adjustable cycle.
  • Solid_Fuel_Man
    What are the 5 wires used?
  • Ironman
    Ironman Member Posts: 7,927
    Your making this harder than it has to be. A common wire is not needed but optional with Honeywell T4. It uses batteries to operate.
    Is this a conventional gas/electric setup or heat pump?
    Bob Boan
