New fuel pump
lutzy
Member Posts: 3
Hi all my furnace leaks oil about 10 drops after it shuts of if the pressure is to high will that make it drip
Could be a number of things. You need to call a pro. Where are you located?All Steamed Up, Inc.
Consulting0 -
Underneith the pump I killed the power and opened the transformer and it is wet in there .0
Leave it off until you get a competent oil technician to diagnose and repair. Pressure has nothing to do with it.lutzy said:Underneith the pump I killed the power and opened the transformer and it is wet in there .
Ok thanks I will leave it off0
Where are you located? We just might know someone who can straighten this out..............All Steamed Up, Inc.
Consulting0
