New fuel pump
lutzy
lutzy Member Posts: 3
Hi all my furnace leaks oil about 10 drops after it shuts of if the pressure is to high will that make it drip
    Steamhead Member Posts: 18,118
    Could be a number of things. You need to call a pro. Where are you located?
    Consulting
    HVACNUT Member Posts: 7,133
    Drip where? Out of the nozzle? Nozzle line? Fuel pump? Oil filter? Help us help you.
    Pics help. And be more specific. And punctuation never hurts.
    lutzy
  • lutzy
    Underneith the pump I killed the power and opened the transformer and it is wet in there .
  • STEVEusaPA
    Leave it off until you get a competent oil technician to diagnose and repair. Pressure has nothing to do with it.
    EBEBRATT-Ed Member Posts: 19,047
    Could be a leaking pump seal. Or a bad nozzle, burner head fouled.
    Either way you need a professional to look at it
    HVACNUT
  • lutzy
    Ok thanks I will leave it off
    Where are you located? We just might know someone who can straighten this out..............
    Consulting
