Bio-Fuel & Reillo Burner
DTech
Member Posts: 1
in Oil Heating
Message:
Can anyone help with this? I just purchased a Buderus with a riello Burner & im seeing leakage under the riello. Someone said it’s because of BioFuel??
Could be. Check -- perhaps with Riello -- to make sure that all the gaskets and O-rings and so on are compatible with bio-diesel. Not all are... I do know that bio-fuel and my diesel tractors don't like each other much!
Though it's just as likely that something didn't get tightened properly.Br. Jamie, osb
Oil burners have had oil leaks since there have been oil burners. What makes you think this is related to biofuel and not just a garden variety oil leak? What level blend are you using?To learn more about this professional, click here to visit their ad in Find A Contractor.2
It’s not the fuel...not unless you’re running a very high bio content. And it wouldn’t happen that fast.
Humor me...
So you had a new install, it’s leaking, and rather then call the installing contractor to come out and fix it, your first instinct is to go on the internet to confirm a “someone said”?There was an error rendering this rich post.
1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
