Bio-Fuel & Reillo Burner
DTech
Member Posts: 1
in Oil Heating
Message:
Can anyone help with this? I just purchased a Buderus with a riello Burner & im seeing leakage under the riello. Someone said it’s because of BioFuel??
Could be. Check -- perhaps with Riello -- to make sure that all the gaskets and O-rings and so on are compatible with bio-diesel. Not all are... I do know that bio-fuel and my diesel tractors don't like each other much!
Though it's just as likely that something didn't get tightened properly.Br. Jamie, osb
It’s not the fuel...not unless you’re running a very high bio content. And it wouldn’t happen that fast.
Humor me...
So you had a new install, it’s leaking, and rather then call the installing contractor to come out and fix it, your first instinct is to go on the internet to confirm a “someone said”?There was an error rendering this rich post.
1
- 125 Chimneys & Flues
