WiFi Thermostat w/Remote Temperature Sensor
BostonGTR
Member Posts: 18
Looking to replace 9 Honeywell T7350's in a light commercial building. WiFi access for remote access/monitoring is critical. Any suggestions or recommendations regarding Venstar, Aprilaire or Network Thermostats? Thanks.
Honeywell Lyric T6 will do the trick.
Good luck, Adam0 -
Honeywell, I like the 8000 line, direct WiFi or the RedLINK flavor with an internet gateway (a max of 4 stats per gateway).0
- 167 Indoor-Air Quality
