WiFi Thermostat w/Remote Temperature Sensor
Looking to replace 9 Honeywell T7350's in a light commercial building. WiFi access for remote access/monitoring is critical. Any suggestions or recommendations regarding Venstar, Aprilaire or Network Thermostats? Thanks.
  • adambuild
    adambuild Member Posts: 425
    Honeywell Lyric T6 will do the trick.
    Good luck, Adam
  • ratio
    ratio Member Posts: 4,264
    Honeywell, I like the 8000 line, direct WiFi or the RedLINK flavor with an internet gateway (a max of 4 stats per gateway).
