How can I tell if I have a gravity fed system?
wcssue
Member Posts: 2
After reading your extensive information on gravity fed systems on this site, I believe that my heating system was at one point gravity fed but I want to confirm that it has been converted. There are two heating zones and there are two circulator pumps at the boiler, one that feeds into the old piping. I also have a pressurized expansion tank for a closed system in the basement . Based on this information can anyone confirm that it is no longer a gravity system?
I plan to install a hydronic towel rack in the upstairs bathroom and I’ve read that they don’t work with gravity fed systems. Any advice?
If you have multiple Zones and circulators, it’s not a gravity fed system. Gravity systems operate as their name implies, by gravity. Hot water is lighter than cold water so it rises by gravity above it. Also, they typically had an open expansion tank in the attic. From what you’ve described you have a forced hot water system, not gravity.1
@Danny Scully,
Danny, we have on occasion split old 4 pipe gravity boilers into 2 zones when converting them to forced flow. It gives some east/west zoning of the house.
But I agree about the original setup being only one zone.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Thanks for your comments. I think you have confirmed that I now have a forced flow system. Any advice on installing a hydronic towel rack/radiator on this system? This is what I’m planning on installing https://usa.hudsonreed.com/ischia-hydronic-white-heated-towel-warmer-65-x-17-75-67610.0
Water, like most people, takes the path of least resistance. The problem you're gonna have is that the towel warmer will offer more resistance than the old rad's, and thus get less or no flow.
The only sure way to address this is to run the lines for the warmer back to the boiler and install a dedicated circulator on it. You may get by just adding a circ to the riser going to the warmer, but it's not guaranteed.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
