Brazing copper LP lines
Solid_Fuel_Man
Member Posts: 2,644
in Gas Heating
Is it acceptable to braze copper (opposed to flare) propane lines? This would all be for 10 psi or less.
I believe NFPA states 1,000 degree F connections, which a braze would be. I've never seen it done, but curiosity has me. I suppose if you purge with nitrogen and treated the whole system like refrigeration.
Just for discussion, I'm not actually considering it!
Thanks all, I would certainly consider a brazed joint superior to any mechanical flare.
Good discussion!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Just curious , I know the reason for refrigeration , carbon contamination from burnt oxygen , buy why nitrogen for a gas line ?
