Mini splits small rooms multi zone
Patchogue Phil_2
Member Posts: 316
Looking to use mini split ductless, multi zone with small bedrooms. 10' x 12' rooms.
I don't see multi-zone package configurations with small indoor evaporators (6000BTU).
Mostly I see 9000BTU multi zoned.
My concern is short cycling of 9000 btu that will not remove enough humidity.
Suggestions? Brands?
Fujitsu makes a 7K BTU inverter ducted unit. That should do capable of doing both rooms
I have an internet-purchased 3 head mini split that I installed that I'm sure is bigger than you are looking for, but I mention it because it has a "dehumidify" setting that I assume slows things down in order to do more humidifying.
I would imagine this feature exists on most or all modern mini-splits...does it work?NJ Steam Homeowner.
All Dehumidify does is overcools with an extremely low fan speed. During mild weather It helps but the "System" still needs to be sized as close as possible. Minimum is minimum!ethicalpaul said:I have an internet-purchased 3 head mini split that I installed that I'm sure is bigger than you are looking for, but I mention it because it has a "dehumidify" setting that I assume slows things down in order to do more humidifying.
I would imagine this feature exists on most or all modern mini-splits...does it work?1
- 123 Chimneys & Flues
