2019 Air Conditioners
John Mills_5
Member Posts: 952
Hi John,John Mills_5 said:Comparison of every company's product line, best I could
http://johnmills.net/AC/
As far as I understood, at least in 2017 the Amana 2 stage and Goodman 2 stage had the same warranties.
My 2017 Amana ASXC16 had a 100 year compressor replacement and 10 year unit replacement.
Maybe they changed it for 2019?
How can you compare units that are assembled in the field?0
ChrisJ, thanks for the correction. The Goodman has a lifetime warranty, 10 year unit replacement. I don't have that. Amana has a lifetime unit replacement warranty if the comp fails so they are longer.
pecmsg, features, warranty & compressor usage is the same regardless of what's done after it is taken out of the box. That's all I'm comparing.0
- 123 Chimneys & Flues
