X-Pump Block with an "on demand" water heater
Alan (California Radiant) Forbes Member Posts: 4,642
edited April 2019 in THE MAIN WALL
Has anyone ever had to add a pump to the on-board Taco 008 to overcome the high pressure drop of the "on-demand" HX?
  • Dave H_2
    Dave H_2 Member Posts: 621
    It should be enough, but then there is always, it depends........
    I wrote a blog several years ago about this, take a look here
    Dave H.
    Dave Holdorf
    Taco, Inc
    Alan (California Radiant) ForbesZman
  • Thanks, Dave!
    That picture you used at the end of your article is from one of our jobs in Berkeley.
  • ScottSecor
    ScottSecor Member Posts: 1,020
    We've used the X block numerous times with very positive results, never needed an additional pump. Its been a few years since we installed one but I'm pretty sure the specs were pretty clear with regard to head and gpm. What are you heating with the X block?
  • We're using Ecowarm panels to heat about 700 []. You can see them in the photo.
    This is the first time we've used Ecowarm. I like the product because it's plywood (3/4") and uses 1/2" PEX.
  • Dave H_2
    Thanks for letting me know where that photo came from. It was in a library, I will tag it properly.
    Enjoy
    Dave Holdorf
    Taco, Inc
  • That job was for Mr. & Mrs. Pickle.
