Does anyone know what the brand/mfg of this radiator is?
garrettgjp
Member Posts: 26
I think it is a burnham but I'm not sure. All of my 5 and 3 tube/column rads have that imprint on the end. I'm just curious, thanks!!
That's a radiator by Kewanee Boiler Company. I sure would be nice to see the whole thing.Dave in Quad Cities, America
http://grandviewdavenport.com1 -
It sure looks clean...is that a recent powder coat job I wonder?
Thank you for the info! I'm not sure how they were painted- I've only owned the home since 2012. The previous owner went through and did a great job refinishing the rads after the house was flooded in 1997. I live in Grand Forks, ND where at least 1/3 of the homes in the city were impacted by the 1997 flood. I'll post a few more pics when I get home.0
I know they made steel boilers, but didn't know they did cast iron. Wonder if they made C.I. boilers at one point also.
Are we sure they didn’t just make the plug?0
No, but I would imagine that the name might be cast in the end radiator section as well. Kewanee did a lot of business in radiators in the Midwest, perhaps in other areas too. I used to own a house that had 1921 smooth round top column type radiators by Kewanee. Name was embossed in the end section. I have a spare Kewanee radiator in my basement that that has a filigree pattern VERY much like American Radiator Roccoco. Also, I am currently assisting in the restoration a Moline system in a Davenport mansion in which all of the radiators are Kewanee brand. They are good solid radiators and are put together with push nipples and rods.Danny Scully said:Are we sure they didn’t just make the plug?
http://grandviewdavenport.com0 -
