Has this gas hot water boiler seen better days?
Cincode
Member Posts: 3
in Gas Heating
I am considering Purchasing a home with this baseboard hot water system. I’ve always had forced hot air heating. It’s a Burnham and looks to be about 30 years old, and has 2 zones. I notice a lot of rust on the maze of pipes and rust on the front and below the boiler. I’m trying to gain some pre-inspection knowledge so I can ask the right questions. I don’t need a huge bill next winter if this unit decides to die, or do I want to keep repairing a unit that is ready for the junkyard. I know t
here is only so much that can be learned from a photo but appreciate all advice offered.
It's not in such a state it would dissuade me from buying. I would put it on my short list of things do you. There are atmospheric and mod cons that are much more efficient than what's there. Coupled with an indirect water heater and ODR, it would be a nice project.0
I agree with @HVACNUT . It looks ok, not sure of it's age. If you like the house buy it. Then budget for it's replacement.
My boiler is 33 years and counting.0 -
I also agree with the ^^^^^^.
You can also take a good look to see how often the boiler has been serviced. The picture shows that the boiler appears to have service tags on it.0 -
Thank you. All of your opinions are very much appreciated. The owner claims the unit was last serviced 4 years ago.0
I would contend that the boiler has never been serviced. The service side of that boiler is the side on the right, facing the wall. It would be impossible to remove and clean the burners with the boiler positioned like that. Cleaning the combustion chamber, observing the flame and making adjustments would nearly impossible. It may be working OK now, but given the age of the boiler and lack of maintenance, it would be reasonable to ask the seller to give a price reduction to make this right.
The circulator is pumping into the expansion tank and there is no air elimination device. I bet you hear a fair bit of air in the pipes when it runs."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Nice gas piping.0
Yes. The gas piping looks dangerous.
Hope the inspector points out that the boiler and water heater have poorly installed gas piping. The rigid piping does not look secured and the plex piping (color yellow) is a leak waiting to happen.
Hope that you have a good and thorough inspection report.0 -
I believe NJ code allows a flex connection.0
@Cincode That's fine if Jersey code allows for it. The thing is, if the hard piping is not hung or in this case fastened down properly, it can roll. The flex piping is not as strong as the black malleable. It can break easier than the black pipe. If it was up to me I would repipe them both.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
