Just when you thought you’ve seen it all
Dave0176
Member Posts: 1,178
Was doing a heating inspection for the mortgage company on one of their rental properties. Came across this gem, shaking my head........ let’s use the skim tap as a radiator runout, and the return runs around the wall into the return. Can’t make this stuff up.....
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Foil-tape-a-palooza on the flue pipe
you'd think it would hammer more than a carpenter
gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
