Register / Duct Window Placement Best Practice?
jeffceo
Member Posts: 27
Hey Guys,
Does anyone have any official source stating that registers ideally should be located under or above windows? I know this is not necessarily building code in some areas but it is the best practice as far as I know. thank you
For heating it should be under the locations with the highest heat loss so that means windows and doors because they loose more than walls. The more registers you have the better. More smaller ones are better than a few large ones but you should take throw and room dimensions into consideration.
Not code as far as I know. You do the best you can0 -
I went from one company who would put the register 12” off the wall on the ceiling, middle of window. every time.
I went to the next company and they laughed at me for trying to fit inside there eves to get the runs 12 inches from the ceiling, middle of window.
They told me just go over the door
Jokes on them?0 -
I know of no such source, but it makes sense to heat people on their coldest side which will be the side facing a cold window where heat loss due to radiation is high.jeffceo said:Hey Guys,
The key thing is to use enough registers spaced equally to keep airflow rates below 30 fpm. Personally, I would shoot for 20 if the situation allows. That will nearly eliminate complaints about both drafts and noise.
This article is long and detailed, but the first two pages have most of what you need to know.
https://www.titus-hvac.com/file/7561/diffusers eng_guidelines2013.pdf1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
