Boiler is gaining water gradually
jlonj
Member Posts: 23
I noticed over the past couple months that the water level in my steam boiler is growing in the eye glass. I always keep it around the red middle mark, but if I check it after a few days, the water is about a centimeter above the middle. It’s slow, but definitely rising.
I have a manual water feed valve. Is that valve definitely leaking? I mentioned it to my plumber, and he seemed skeptical that this would happen. Is there something else that could be causing my boiler to gain water?
It’s a little odd to me since the boiler and feed are only like 5 years old. Seems a bit early for a leak to form, in my opinion.
pictures,
and is there domestic hot water attached?
known to beat dead horses0 -
The ph level of your water might be rising over the years causing what appears to be build up of water in your sight glass.
The feed valve could be weeping water by if some debris is caught in the valve. Do you have a auto feed with a wye strainer installed before it ? You should. This strainer catches particles in the water that could cause this.
(Just looking to clarify as to the type of water feeder you have )
If there is a bypass valve at the auto feeder, (if you have one ) make sure that that valve is also closed tightly.0 -
@jlonj
If you do not have an automatic water feeder then your manual valve is leaking by. if you have a tankless hot water heater coil then that could have a pinhole in it which would cause the same problem.
change or check the manual valve by installing a union downstream of the valve, then it's either problem solved or move on to the tankless coil. if you have an auto feeder that should be checked1 -
Feel the pipe 8" above and below the water feed valve, if water is flowing they will both be cold. If no water is flowing they will be cool but not cold.
3PSI gauge0 -
@Intplm. @neilc
Sorry for the delay, y’all - here is a link to pics of the setup:
https://imgur.com/a/9gKWDei
I don’t have an auto feeder or water tank coil.
Only other thing I could think of is that the eye glass has some rust in it that could somehow be throwing off the level? I had the boiler cleaned, but it was very dirty, so it was still a little rusty after the cleaning. Water still seems to only be going up though - it never goes down.0 -
Don't overthink it. If the water level is going up, water is getting into the boiler from somewhere. The best bet is a leaking valve. Don't assume anything about the valves!Br. Jamie, osb
Cleaning the sight glass and its fittings all the way into the boiler, (also pigtails) should be done whenever the boiler has major "cleaning", IMO.
Is the copper pipe with the yellow handle "Raven" valve the only water connection to the boiler.
That valve could have some debris in it that does not give 100% shut off. I would replace it with a high quality valve. And add a union under it so it could be observed for leaking if needed in the future.0 -
Hard to say. But that yellow handle on the ball valve does look like it is not closed completely.
It hard to say because ball valve handles do have some play in them.
Take a screwdriver, put the metal end to the valve and the handle to your ear and listen for water passing by. Might give you some idea if water is passing the valve.
Wouldn't hurt to change that valve anyway.0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
