Flow splitting a Tee
adavis
Member Posts: 11
in Gas Heating
good day, I am looking for some opinions on the subject of Flow splitting a Tee. were a tee is fed into the branch, and split into two runs supplying two locations or appliances. is the pressure drop, turbulence or split amounts higher then adding an elbow to the the tee to change direction, In this case natural gas is used.
I have added pictures or clarification
Thank you for you time
1
@adavis
feeding into the branch of the tee is called "bullheading" and it should be avoided it's not considered "good piping practice"
However, it is done and if the pipe is "oversized" there will probably be no issues. But on a new job why not just avoid it?
In your picture circled red put the feed into the run of a tee on the 30' pc and feed 1 appliance off the branch of that tee. The other end of the tee gets a nipple and a 90 to feed the other appliance1 -
Thank you everyone for the information0
- 117 Geothermal
