Steel / aluminum wall radiator panels
bob eck
Member Posts: 930
Anyone know of a brand steel / aluminum wall radiator panels that can be used to replace cast iron steam radiators?
I would think that without the thermal mass of cast iron they would not provide comfortable heat, especially at 1CPH.
They might be ok for hot water heating, but not for steam..—NBC0 -
Look at steamradiators.com. However, NBC's comment would still apply.To learn more about this professional, click here to visit their ad in Find A Contractor.1
Depends on the building? If heat loss is low enough thermal mass of room may suffice? Especially if panels are located so that heat is mostly radiant versus convection.nicholas bonham-carter said:I would think that without the thermal mass of cast iron they would not provide comfortable heat, especially at 1CPH.
- 50 Industry Classes
