Steel / aluminum wall radiator panels
bob eck
bob eck Member Posts: 930
Anyone know of a brand steel / aluminum wall radiator panels that can be used to replace cast iron steam radiators?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    I would think that without the thermal mass of cast iron they would not provide comfortable heat, especially at 1CPH.
    They might be ok for hot water heating, but not for steam..—NBC
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,307
    Look at steamradiators.com. However, NBC's comment would still apply.
    kcopp
  • jumper
    jumper Member Posts: 2,479
    Depends on the building? If heat loss is low enough thermal mass of room may suffice? Especially if panels are located so that heat is mostly radiant versus convection.
