New home with 300 gallon tub and small radiant heating load
solradman
Member Posts: 58
Looking at a job that will have a 300 gallon soaking tub and a heating load of 37,551 Btu's. Home will have radiant floors and plan is to using a mod-con boiler. Would a 199,000 Btu boiler and 80 gallon indirect be better than a couple tankless units just for the bathroom with tub. Thinking the tub will need 250 gallons as fast as possible. Any recommendations?
Hello, Any chance they would go for a smaller capacity tub? If so, you could combine systems. Looking on-line, I see 60 gallons for deep soaking tubs. 300 is a lot! If they are inflexible, I'd look at tankless units jut to serve that tub. You're probably looking for at least 5 gpm at a 90 degree rise for half of the water. That's 25 minutes to fill!
300 gallons could be OK if the water were treated and the tub stayed full, like a hot tub.
Yours, Larry0 -
@solradman
Where I come from that's not a soaking tub it's a swimming pool!
If they have the $$$$ for that they have to have the $$ for the water heater to feed it.2 -
300 gallons is a big tub. I have never seen one that big without it's own heater."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Two 199,000 tankless has water heaters will give you about 11 GPM
RINNAI makes a demand duo 199,000 tankless on a 119 gallon storage tank. They now have two 199,000 tankless on a 119 gallon tank.
Vaughn has 119 gallon indirect water heater that you can get two coils in it.
Check those options out.
How many times are they going to fill a 300 gallon tub?
Is this on a municipal water system or on a private well?
If on a private well system what how many GPM does the well pump produce. If the well pump only pumps 7 gallon per minute that is all you are going to get.
If on a well system do they have their own septic system that 300 gallons dumping into a older septic system can cause problems.
Tankless shines in this example. I agree with Bob eck, two will give better results. Will this place have a private sewer and well, or municipal?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
