Insulation Inside of Steam Boiler has chipped off -Is this normal?
JRobert
Member Posts: 6
I have an Burnham Independence Steam Boiler - 17 years old.
I recently noticed some debris below the burners and determined that it came from the left side and ceiling of the chamber. It appears to be pieces of hard insulation that has chipped off over time. Interestingly, the right side has not chipped off that much.
Is this a normal occurrence in the life of a steam boiler or a sign that it is time for a new one?
Thanks!
Thanks!
Oil fired? Sounds like it may be time to have the chamber relined.0
No, it's a steam boiler. I didn't know that the combustion chamber could be relined. Any idea how much it costs?
Here is a picture of the combustion chamber minus the burners.
I am sure that can be replaced. Download the boiler manual from Burnham and see if you can identify the part #s.
The deterioration I see in the picture is pretty minor. If that is the extent of it I wouldn't be overly concerned. If you have other areas with the same deterioration then I would address it this summer0 -
Thanks for your help!0
I’m not sure but you might be able ot just apply refractory on top of it. It’s a cement-like powder mix that I think you just add water too. I’ll look it up.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
