Steam vents not working?
Jaypair
Member Posts: 6
All of my steam vents that look like this are constantly giving off steam
The ones that look like this don't. Is that the way they were designed or have they gone bad?
I want them all to constantly give of steam when the boiler is running
Ah... no. Steam radiator vents are designed to close when steam hits them. The ones that are giving off steam are busted, and need to be replaced.Br. Jamie, osb
Releasing steam means fresh water in the boiler, excessive fresh water means an early death to the boiler.Jaypair said:Really,lol
I actually prefer when it gives off the steam because it gets the room warmer1 -
I was just about to ask if there's risk of any lng term damage0 -
Are all the air vents on the opposite end of the rad from the steam valve?0
Yes, they're all on the other side0
and only one pipe going to the radiator ?
known to beat dead horses0 -
You need to check the boiler pressure gage and see if the boiler is building steam pressure. It is better if it is not building pressure0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
