Steam vents not working?
Jaypair
Jaypair Member Posts: 6
All of my steam vents that look like this are constantly giving off steam
The ones that look like this don't. Is that the way they were designed or have they gone bad?
I want them all to constantly give of steam when the boiler is running
    Jamie Hall Member Posts: 25,990
    Ah... no. Steam radiator vents are designed to close when steam hits them. The ones that are giving off steam are busted, and need to be replaced.
  • Jaypair
    Really,lol
    I actually prefer when it gives off the steam because it gets the room warmer
    ethicalpaulSeanBeans
  • Fred
    Fred Member Posts: 8,542
    Also, those vents should be on the lower/center of those radiators for more even steam fill. I assume this is a one pipe steam system, Right?
    luketheplumber
  • KC_Jones
    KC_Jones Member Posts: 5,883
    Jaypair said:
    Really,lol
    Releasing steam means fresh water in the boiler, excessive fresh water means an early death to the boiler.
    2014 Weil Mclain EG-40
    luketheplumber
  • Jaypair
    I'm not sure m not sure about the system, it's a 3 famil brownstone
    Most of the other vents are much lower on the radiator
  • Jaypair
    Thanks for the info
    I was just about to ask if there's risk of any lng term damage
  • JUGHNE
    JUGHNE Member Posts: 11,397
    Are all the air vents on the opposite end of the rad from the steam valve?
  • Jaypair
    Yes, they're all on the other side
  • neilc
    neilc Member Posts: 3,024
    and only one pipe going to the radiator ?
    known to beat dead horses
  • Jaypair
    Yes,all of the radiators are like that
    EBEBRATT-Ed Member Posts: 17,705
    You need to check the boiler pressure gage and see if the boiler is building steam pressure. It is better if it is not building pressure
