Indirect concerns
Bob_115
Member Posts: 40
I am considering installing an indirect water heater in my 1000 sq ft ranch. I see some posts talk about listeria being an issue in these tanks. Is this a real concern and what would prevent that. Secondly does long island water have a high chlorine level that would shorten the life span of a stainless steel tank?
It's Legionella... but whatever, as @Steve Minnich said, keep the tank at 140 F and mix it down and you'll be fine.
And it's not chlorine that is the problem, it's chloride -- and that shouldn't be particularly high on Long Island, unless you have an ion exchange water softener.Br. Jamie, osb
Thanks for the comments and correction. Knowledge is power!0
What type of control would I need to prioritize DHW over space heating in a hydronic system?0
What do you have for a boiler? Oil, atmospheric gas, power gas, mod/con?
Your question depends on the boiler. Also what size indirect, and what are your domestic hot water demands?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I have an oil fired boiler with a tankless coil. My hot water demands are low as we are a retired couple. I was thinking that a small indirect would work for us.I may upgrade to a smaller oil fired boiler as mine is oversized.0
Take a look at the Purepro indirect water heater built by Amtrol for F W Webb. Plastic lining water never touches metal. Also Vaughn makes a stone lined and new plastic indirect water heater. Glass lined indirect water heater also works good if you have high cloridies.
If going to a new oil fired water heater take a look at the Trio oil boiler build for F W Webb. You can do outdoor reset with this boiler. This boiler can be fired with oil, natural gas or LP gas.
Find yourself a good heating contractor and they can help you with your needs and concerns.https://www.youtube.com/watch?v=5gaD_Nz2dGY&feature=share
http://www.pureproproducts.com/htg/trio_boilers.html
In my area, we have particularly bad luck with the plastic lined amtrol tanks. Many leakers, most dont make it 5 years.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
1000 sq ft, only one thermostat? Usually a priority control isn't necessary for that setup but an outdoor reset control with DHW priority control is nice to have for efficiency and fuel consumption. With that setup you will only heat up the boiler to its maximum temperature during the coldest days of the year and during DHW production
Tekmar controls are awesome. Honeywell makes a kit that goes with their digital aquastats that does it all too.
I have a amtrol boilermate, 8 years old and no problem. Definitely take water quality into consideration when choosing a tank. If hard water or high mineral content is an issue use a Aquapure scale stopper.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
