Gas Water Heater in the insulated garage
afedorov
Member Posts: 2
in Gas Heating
Hello,
I am thinking about converting my garage to an office space. That will require insulating walls and more important insulating garage door that will significantly reduce air circulation in the garage.
Will it affect Gas Water Heater that is installed in the garage?
It should not, as long as enough there is enough free air for the gas water heater to breath. Don't build walls around it or close it in.0
How can I check if there is enough? I assume most of the houses have gas water heater in the garage, so if owner converts it to leaving space, lack of ventilation should be a common problem if it is a problem0
Hello, As long as you're doing a remodel, why not consider installing a heat pump water heater? Running power to it should be pretty easy and then you eliminate the combustion appliance in a living space, and a ducted unit could provide some other benefits. Heat pumps do make some noise however...
Yours, Larry0 -
What is the BTU input to the water heater? What is the size of the space that will contain the water heater? Is the water heater connected to a chimney?0
- 116 Geothermal
- 15.8K Strictly Steam
