Heating a open top tank
Hello all ( new here) question please I have a open top tank I need to keep at 90 degrees I’m wanting to put in a heating element with a thermostat I have a hot water heater in my shop now and I’m wanting to know can I just unplug it and use the power cord to run the element I’m putting into my tank
    Jamie Hall Posts: 27,745
    That's a little vague... what power is the water heater? What power is the heating element in your tank? Is this a fixed installation (requires a hard connection -- no plugs -- according to code) or does the heater in the tank float around, like a stock tank heater?
    hot_rod Posts: 28,221
    You can buy immersion elements that hook over the side of open tanks. A larger version of the travel coffee mug heater elements.
    Or some stock tank deicers as Jamie mentioned.
    Why do you want to do that? There may be a better way of achieving your purpose.
    90 deg F (32 degC ) is a nearly ideal temperature for cultivating legionella ( or any other random bacteria) in your tank. Also, immersion heater thermostats can fail by arc-welding themselves closed (permanently on) and the water may boil. If it's a plastic tank, it may soften and collapse, releasing a boiling waterfall. That has happened.
  • SuperTech
    SuperTech Posts: 2,669
    If you really want to do this just go to the pet supply store and buy a heater for a large aquarium.
