combi venting through floor
maxsoda
Member Posts: 4
I'm installing a combi boiler in a 7' crawl space. I want to vent the the combi vertical through the above plywood (osb) floor, into the above main floor stairs closet, and then 90 to the outside. I can not find anything concerning venting though a floor and then outside (everything is through the floor and through the roof). What is the code concerns when venting through the floor. The combi 3" pvc exhaust temp will be below 144 fahrenheit.
Crawlspace will need ot be sealed and insulated. You can’t install condensing appliances where it could freeze.
No sure on code. Should only matter the total equialvanent lenght of pipe. But again, if the crawlspace is cold, you can invite issues as the exhaust temps get too cold and invite freezing at the exhaust.
Also a damp crawlspace will destroy these units fast. Condensation inside the cabinet.
I strongly recommend you find a closet near an outside wall for it if possible. Easier ot run longer header than vent pipe. Keep the unit in conditioned space.0 -
Keep the unit in a clean, conditioned space that an adult can easily fit in and still be able to access every component of the boiler.
The boiler shouldn't be kept hidden and out of sight. It should be proudly kept on display, unlike a stove or refrigerator this appliance keeps you and your family warm and alive when the cold outside is life threatening!
Treat your boiler like you would a sports car. Don't buy the least expensive option, keep it clean and serviced. Take pride in your heating equipment, it's not cheap to operate!3 -
I agree with the previous comments that you'd be much better off putting the boiler in the closet and not the crawl space.
As far as the vent pipe goes: it can penetrate the floor as long as it's properly fire stopped and protected from physical damage.Bob Boan
You can vent category 4 through house, but it must be enclosed into fire rated enclosure (2 layers if 3/8 sheetrock), with fire rated access panels for routine inspections, also, i would install CO detectors at each floor, interlocked with boiler, so, in case of CO presence they would shut down boiler. It must be filed by architect with dob.Gennady Tsakh
Absolute Mechanical Co. Inc.0 -
Thank you for the response. The crawls space is basically a basement (cement floor, ICF walls, insulated, will be heated). The main floor does not have room for all the radiant plumbing equip. The house is in the mtns at about 10,200 ft. Snow is a big issue. That is why i want to run the vent through the floor and out.0
Plumbing and can go in the crawl space, the boiler should be above, ideally.0
You mentioned 7' crawl space, does that mean it's 7' tall?
Crawl space is 7' tall.0
That should be fine, insulate the pipes if going into a cold area. Size and slope per O/M.
D0 -
Why do you call it a crawl space? Sounds like a basement to me. Lots of basements are less than 7' around here.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
