Boiler
RWALD
RWALD Member Posts: 23
Lochinvar or Triangle Tube Which direction should I go? Thanks for advise
    Jamie Hall Member Posts: 26,167
    Whichever your preferred installer prefers to work with.
    DocfletcherDZoro
  • Gordy
    Gordy Member Posts: 9,546
    If the two choices are what the companies bidding are using, I would say lochinvar. Preferably the 10:1 turn down ratio.
    With zero details of the application it’s hard to say.
    With many control offerings through brand names. It’s really not the best answer anymore of which ever one your installer uses. Maybe you have choices.
  • RWALD
    it's for a big hog barn btu load of about 3 million The boilers are going to supply hot water to NU-era Heaters which is basically a water heater
  • Gordy
    Both are nice boiler manufacturers. So stick with parts, and service availability.
