Boiler
RWALD
Member Posts: 23
Lochinvar or Triangle Tube Which direction should I go? Thanks for advise
If the two choices are what the companies bidding are using, I would say lochinvar. Preferably the 10:1 turn down ratio.
With zero details of the application it’s hard to say.
With many control offerings through brand names. It’s really not the best answer anymore of which ever one your installer uses. Maybe you have choices.0 -
it's for a big hog barn btu load of about 3 million The boilers are going to supply hot water to NU-era Heaters which is basically a water heater0
Both are nice boiler manufacturers. So stick with parts, and service availability.0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
